I just purchased a 1986 jd165 with a fb460v. guy before attempted to rebuild carb, when I got it the air cleaner base was broken so I got a new one. got it reassembled and engine surges and no matter where I turn the mixture screw its makes no difference. so I took carb off and apart and it appears the main nozzle has been butchered. by this I mean clamped with something and sanded with heavy grit paper and not to mention the screwdriver slot is no longer there and was luck to get it out. from my auto experience I did a no no, I filed the top of it flat and made new slots and reinstalled. it runs but still surges. so my question is new or used carb? new main 13a main nozzle which appears to be non available, or should I be looking for something else? not sure what all he has messed with, any help would be greatly appreciated!
