Fastrak - Any Issues?
I have a 2016 FasTrak 54 and love everything about it except for one aggravating thing..... about every 15 hours I have to pull off the center roller and grease the bolt and sleeve inside or the thing growls like crazy as it's turning over in the grass.....
It isn't hard to do but it's a little bit messy and it just tees me off every time I have to do it. They should also have a quick release cover on the outsides of the decks for quicker cleaning.... other than that it's a homerun.
Mine is about a 2002 model, and the only issue up to a couple years ago was when it was new. The pump screens clogged with some plastic shavings because of a bad design, but I flushed and changed the oil and no issues since. The original Denso plugs went bad after two years and installed some champion and no changes ever since, still running great. 20hp Honda with 52 deck
Just oil changes, blade sharping, and not a lot else
Last year one flat tire and this year 5, so I've ordered some run flat tires from Hustler for the front.
