jmartin0801
- Aug 16, 2026
- 5
I took off the fuel tank andWhat area of the unit were you working on?
Thank you I will try that. I was trying to look at the ignition cable since I don't know if I'm getting a spark from my new spark plug. I also don't think I tested it correctly the first time.It is the fuel tank spacer that mounts under the front bottom edge of the fuel tank. Goes into this hole on bottom of tank View attachment 74254
Thanks IL, I knew I had seen it before, but I’ve forgotten more than I
You were correct, thanks again !It is the fuel tank spacer that mounts under the front bottom edge of the fuel tank. Goes into this hole on bottom of tank View attachment 74254
