Hello everyone, I have an exmark lazer 48''cut LHP4821KA. The problem is no power to start when key is turned. If I cross the starter solenoid it starts, while it's still running, if I try to engage the PTO there is no power flowing through the switch to engage the deck. I took the panel off that holds the s/switch, PTO/switch, choke, throttle, etc. When I turn the key and put my finger on each of the black relays or what ever they are. I can hear and feel them click like they are energised. I have not found the fuses yet. What do use think might be wrong Thxs Deanner
