EXmark mower LZ20KC604 keeps blowing fuses
Jonmgold
I have an EXmark mower 2002 that keeps blowing the fuse have checked most of the wiring have not found a short yet. Have checked all safety switches. It unplugged the rectifier and it will not blow the fuse but it still won't start. If I have the trigger connected to started and both the start and kill relay are not installed it will blow a fuse. Needing help to find the issue I have put a new starter bc I thought it was a bad selnoid but I was wrong. Thought I found issue when I found a dead mouse but no burnt or shorted wire. Any help is appreciated.
Jonmgold
Here is a wiring diagram
Bicklebok
Did you find the problem? WHich model Exmark is it and which engine?
That mouse may have chewed through a wire and its grounding out.
