Hi everyone thanks in advance for any help. I have a Exmark Lazer Z with Kohler Command SP27 model CH740s Spec PS-CH740-0045 serial 3416109201. Sometime around 2015 it started blowing oil and skipping so I put it in my building and started to use and older mower I had. I had been through cancer and chemo and dealing with chemo brain lol. Pulled it out couple weeks ago and dug in , the oil was leaking from the gasket at the crank case vent. I replaced gasket and filter, installed new plugs, oil change serviced it and fired it up. It ran for about 30 minutes of cutting doing excellent then lost power.
I took it to the building and it would idle but at full throttle pop through the carbs like maybe no timing advance. I ordered and updated the coils to the new Kohler style and removed the DSAM ignition and coils. It was still doing same thing. Checked Leak down and both cylinders were 80/75 and compression on both was 150 with engine cool, I would think even higher on a warm engine. I ordered a carburetor and installed same results with both carbs. Any pointers or suggestions would be greatly appreciated still dealing with chemo brain and old age so cognitive skills not what they used to be. Thanks again Tony
