Exmark lazer Z 2001 era CUT issue
born2ride
I have own this mower for 10 years now, in the past few it seems not to be cutting as well. The issue is when grass gets longer 7-10 inches the machine will leave two tall lines of grass where the blades meet. Note the grass is dry by the time I get home to mow, 3-5' grass is not much of an issue but does it slightly when running through taller grass. I have changed blades, tried index blades in different positions, changed spindles, most of the pulleys on deck, new belts, mower rpm 3800 or so. the clutch is a few years old. I am at a loss why it's doing this now. Looking for some input
