Exmark Jack. - Jack Mount Kit
Captain Belly
Thought I would share a neat device that allows me to lift my Exmark high enough to access the blades.
Are used to hoist the front end up with a log chain from the header over my barn door, but this thing is a game changer.
Still prefer a proper lift.
HFT does have a couple. A 300 lb (61523) and a 750lb (63298). Now 750lb one need the H lift part removed as gets in the way electric PTO clutch removals. The only other problem into with 750lb one is that sometimes a pair of 2x8 runners is need for some mowers as the deck does not clear the jack's foot.
Weird. My Exmark Radius came from the factory with the jack socket already welded on. I bought the bulldog jack for around $60. I assumed it was standard across all models.
A good tip is to remove the jack crank and use a cordless drill. Just make sure the base of the jack is on the ground when removing the crack or the shaft will drop down.
