Ric
- May 7, 2010
- 142
- 5,765
[h=6]Exmark Brings EFI Propane Innovation to the Vantage S-Series Stand-On Rider[/h] [h=2]By Drew Tyson, June 2, 2015[/h]
Exmark has unveiled the latest addition to its industry leading line of EFI propane commercial mowers the Vantage S-Series Propane 52 stand-on rider. The new model uses a state-of-the-art Kohler EFI propane powerplant that delivers significant increases in fuel economy, performance and reliability along with being the most environmentally friendly engine option available today.
The new stand-on machine joins Exmark痴 existing EFI propane Lazer Z and Turf Tracer models, providing the broadest product lineup in the industry, allowing landscape professionals more choices from which to choose products that best fit their needs and enjoy the reliability, economic and environmental benefits of EFI propane power.
Exmark Director of Marketing, Daryn Walters, said an increasing number of landscape contractors are turning to propane as a way to reduce costs, increase profitability and reduce impact to the environment.
典ime and again, we hear that fuel is one of our customers largest expenses, and increasing fuel costs have put a serious dent in the profitability of many contractors across the country. More and more of these folks are turning to EFI propane powered equipment as a way to reduce their fuel bill and get more work done with fewer resources.?/p> The Vantage S-Series Propane machine features the groundbreaking Kohler Command Pro PCV740 EFI propane powerplant. The engine痴 automotive-style closed-loop EFI system delivers significantly increased fuel economy, reliability and improved performance, combined with easy, no-choke starting. It precisely adjusts fuel/air mixture settings in real time for optimal performance at any altitude, any temperature, in any conditions.
The efficiency of the EFI system reduces fuel consumption by up to 40 percent compared to carbureted propane engines.
The Vantage S-Series Propane model is available with a 52-inch UltraCut Series 4 cutting deck. The deck features Exmark痴 patented Flow Control baffles to provide an unmatched quality of cut, and the welded steel deck construction features 7-gauge high-strength steel reinforced spindle mounting rings for top-notch strength and durability. Blade spindle assemblies feature rugged cast aluminum housings and zero-maintenance sealed heavy-duty bearings to maximize service life, even in the most demanding commercial cutting conditions.
Learn more about the 2015 Exmark Vantage S-Series Propane stand-on riding mower at Exmark.com.
