Exhaust Valve Keeper Came off...
Schmiedl
So after some work and cleaning I've brought my 461707-0147-E1 19.5 opposed piston Briggs back to life. Well after running for 5 min I hear this ratteling sound and notice some smoke. Up on removing the cover from the valves and piston I find that my exhaust valve is loose as in no longer attached to the spring.The keeper (494553) is laying in the bottom of the valve compartment. Any ideas on what could cause this to come appart?
Hate to say it but the edge of the valve ( when the keeper locks in) is probably worn. You can try to put it back on and if it pops off again replace the valve. Could be the keeper itself but I highly doubt it.
Schmiedl
Is there any special method to outing is all back together?
Don't know what you mean by outing
Schmiedl
Got it fixed, the spring was worn out.
