i have a Briggs and stratton 18,5 hp single cylinder vertical shaft engine on a jd zero turn . was having problems with loss of power then the carburetor started acting up. i replace it as well as the new coil plug etc. checked timing valve clearance , push-rods are straight, compression checked out just fine. with the new carburetor same things not as bad but a lot of exhaust coming out of intake (carb). i checked valves a lot more thorough and it seems the exhaust isnt opening up all the way ( just my opinion).
what would be causing this and what is the fix for it. any help would be greatly appreciated.
thankyou
brian
thankyou
brian
