I just rebuilt my 16.5 HP B & S 28W707-0121E1 motor and it is hard starting (need to take the air filter off to get to start). I'm thinking it might be the rocker arm gap which both are set to .006. When it is running, it has a loss of hp and there is blowback through the carburetor which is most likely the reason it goes through the gas. Any help is appreciated!
