error code b-in now
jag0315
So after the break in code kicks how do you get it off the screen, after you change the oil.
jag0315
6-1 in now code means “break in hours” after 5 hours that code kick to change oil in it. Due to your motor is broke in. Metal shavings, oil that the manufacturer used, stuff like that is done, and change it.
