Engine won't stay running
Scrubcadet10
Moderator
Staff member
I replaced the Briggs engine on a poulan push mower, with the 799983 Short block,original model # was 122t02-1207-B1.
I can keep it running by manually holding the throttle open then once I let go it dies. I made sure the governor rod was adjusted right (according to a Taryl video) main jet is clear, and carb was working when swapped over.
I’ll bet if you pull the carb you will find that the float level has dropped, causing a lean running condition.
cpurvis
Could be a vacuum leak.
Scrubcadet10
Moderator
Staff member
Float was level as could be...
Cpurvis, never dealt with that kind of problem, what usually causes it...?
Bad or improperly installed gasket. On some engines, a bad o-ring. Anything that seals the intake system between the carburetor and cylinder head, including throttle shaft seals. An engine with a bad leak usually won't idle.
