Craftsman Model: 247.37031
Briggs and Stratton Model: 126M02-6863-F1
I was mowing and the engine was stalled the grass was way too long. It wouldn't restart. I was using last years gasoline, so I was pretty sure that was the issue since I've had that issue before. I emptied the tank and put in new gas. Won't start.
I tried putting a little gas in the carb and still no luck. Then more and more gas.
It spurts gas out of the carb when I try to start it (air cleaner off). I tried with holding the choke plate open with a screw driver and that didn't work either. It's been a half hour resting, just tried again. Nothing.
Any ideas what to try next?
