carcrusher123
- May 24, 2014
- 1
I have a Honda GX620 twin engine. I have a fuel pump running to the engine. When I turn the key to the on position the fuel pump comes on, as I want it to. When I turn the key to the start position the engine starts. This is how I want it to work. The problem is when I turn the key to the off position the engine won't die until all the fuel is used up in the carb. The fuel pump does stop, but for some reason I still have fire to the engine. How can I wire the engine to die as soon as I turn the key to the off position.
