You need fuel ,spark ( at the correct time ) compression to run.
Squirt either gas, or parts/carb cleaner down the Carburetor throat behind the air filter, if it starts then dies most likely a fuel issue. If it doesn't fire, either no spark, or valves are not working.
Then take out the spark plug and squirt some down the plug hole. If it Fires, you have either a valve or valve timing issue, if it doesn't fire, most likely no spark.
If you get no fire, take off The blower housing to get to the ignition coil, and unplug the black kill wire. Then try to start it. If it doesn't start, your coil is bad.
