Engine Engine turns over, but will not crank.
RobertMo65
I am new to the forum so play nice.
Here is the background information:
John Deere Z425 (2011) with Briggs and Stratton 23 hp (model 44L7770144G1)
When I went to start the engine, no problem. When placing choke lever to run it shuts off and will not crank again. The engine turns over but that is it. Things that have been checked this time or replaced last time: Spark plugs are clean, replaced last year, tested with a plug tester. Fuel pump replaced last year and tested this time for fuel discharge. Replaced fuel filter last year, verified it is clean. I don't suspect any of the safety interlocks because the ones I have tested won't allow the engine to even turn over. Checked the oil in the operating band. I have took it to a shade tree mechanic last year and of course it started right up when I got there. Any ideas or suggestions are greatly appreciated.
Thanks, Robert
