I have a CC 42 inch with a Kohler Twin Courage engine and I bought the tractor at the beginning of the season last year.
It seems that when the deck is not engaged and the engine is running in any throttle position, the engine does not running at a consitant speed. Sounds like it pulsates at different rpm’s. Should I be calling the dealer or could it be just a fuel issue since I did fill the tank with non enthroned fuel, with stabilized in early December.
