Engine Swap?
Klapaucius
I bought three LB''s, planning on fixing up the 10515 and R7268 and taking parts off the S19ZPN because the engine was toast. The R7268 is now running like a champ and the 10515 is missing too many parts to make it worth fixing. I also thing the drive unit is gone since I can't get it to move through the gears or go into neutral. I think somebody started parting this out and then sold it to me, my mistake. The engine is still good though. I am now thinking that I can put that engine on the S19ZPN, is that possible? Any feedback is appreciated.
AnthemBassMan
Should be a straight swap since both are F engines and have aluminum decks.
L8R,
Matt
AnthemBassMan
It fit perfectly, but then somebody wanted the 10515 for parts with the engine, so I had to undo it all! Lol
Unfortunately that’s the way things work sometimes. But now you know that everything swaps over. The only thing is swapping an engine from a steel deck to aluminum, you have to use the muffler plate that’s for the deck. The engines are the same, just the muffler plates are a little different.
L8R,
Matt
