engine swap
tonymsanchez
I own a 638 RL yard machine ,with a formula 13.5 hp, tecumseh motor. what kind of motor can i swap out with. I heard watch out cause of need to make sure of same kind of mounting bolt pattern
Scrubcadet10
Moderator
Staff member
The main thing is mounting pattern, and crank shaft diameter and length.
There is a website (smallenginewharehouse.com) and you can select your specifications to find a replacement engine.
