My Craftsman mower had a 13HP Briggs 28m707 motor and I have a briggs 310707 17hp motor I would like to put on it, the old motor blew up and oil poured from it so there is no fixing it. The wiring is similar but different, can someone tell me what wires need to be hooked up so it can run and also can I swap the carb from the old motor onto the larger motor? The 17 HP motor seems to have carb problems as the fuel will fill the cyld. quickly after cranking the motor over ...I had to remove the plug and crank the motor to empty the gas. I am used to working on V8 motors but have never worked on the small engine's like these...Thanks for any help.
