hovercouch
- Jun 5, 2013
- 1
- 2
Got a push mower front wheel drive with a Briggs and Stratton engine model 122L02-0115-F1...last week halfway through the job the engine speed just suddenly cut in half and was on the verge of stalling. I took apart the carb and blasted out the jets with an air compressor, cleaned out the gas tank and fuel line, reassembled and it ran fine for a couple minutes then got the same problem again. So I bought a new spark plug and air filter, ran fine for about 15 minutes, same problem. Bought a used magneto/wire, ran fine for 15 minutes, same problem. There's no throttle or carb adjustments and putting extra tension on the throttle cable changes nothing. :confused2:
