MiltonDeere
- Apr 19, 2015
- 1
- 6
New to site but need your help.
I have a JD LX277 lawn tractor. When getting it ready for mowing after along winter, I did all that I usually do: fresh gas, check/replace oil/ clean deck/etc.....
When I fired it up for the first time (and subsequent), I pushed the choke up to start and once started, let it spring back to original position. The engine continued to run fast and then even faster. Throttle was kept on low as when started. The only way I could slow it down was to push choke to up position again and hold it there. Throttle doesn't seem to do much since it was already running fast.
I removed engine cover to check movement of things and all seems normal.
Any suggestions besides a repairman?
Thanks much.
Tim G.
Thanks much.
Tim G.
