Engine revs up by itself
geo77
Hi all,
I just got a craftsman riding mower with a Kholer engine. The engine turns on and idles fine, however when you give it a little gas, the engine revs up by itself where I have to turn it of to stop it.
I'm kind of a newbie, please be descriptive on your explanation.
Any help what it could be?
Thanks for any help before hand.:thumbsup:
Hi all,
A lot info needed about the engine and mower
model of Kohler,hp
Craftsman sell 100's of mowers from many different manufacturers.
Yes, of course, sorry about not giving that information at the beginning of the thread.
917252700 CRAFTSMAN LAWN, TRACTOR
18HP Twin
Kohler Magnum
ALMOST.... see examples .... engine numbers should be located on engine ....
37276d1524535430-dealer-says-check-oil-dip-stick-screwed-dsc01109-jpg.jpg although this is a Kawasaki yours may be similar on your ENGINE ........ click on pic to enlarge
Recall.2011.11704.11704c.jpg this would be for your MOWER (something similar)
I double checked and the only sticker I see under the seat is the information I posted above.
model number: 917.252700
Serial Number: 011195C....
Found the engine model number in the user's manual.
ENGINE MODEL NO.- MV18S- PS58560
I don't see anything on the engine, maybe if I pull the covers off?
What steps should I take to troubleshoot and find the cause? And fix it
Section #6 in manual...after carb info.
Make sure all linkages and springs are connected in the right places.
Do the simplest checks and adjustments first.
I believe it has been done, by previous owner, but I will double check and post.
