Engine problems with John Deere Z665
JDZ665
Have John Deere 27 hp twin V Z665 less than year old. Was cutting the grass yesterday and heard tapping starting in engine. before I could shut it down, I heard a loud metalic clank right after the engine backfired. Could this be a dropped valve? Engine seems to be locked up.
Could be a couple of things. Take it back to the dealer, as a one year old unit should be covered under you warranty. Did you check the oil?
chance123
Sounds more like a blown rod rather than a dropped valve.
