Engine Model Help
Adamski
I have a Murray 22265X8E mower with a Briggs and Stratton 6.0hp engine. I'm trying to get a carb rebuild kit for it, but don't have the model number for the engine and I'm not home to check it. Anyone have any idea what model engine they used on these?
Thanks!
Adam
Ok, I had the wife get the model number for me.
It's 12H802-3378-B1. I typed it into google and there's absolutely nothing on this engine. Any ideas?
The part number for that kit is....498260 Carburetor Overhaul Kit.
What is in the kit is......
Needle/Seal part No 398188
O-ring seal intake manifold part No 270344
Float bowl gasket (sold in kit only)
Sealing washer (sold in kit only)
Dust seal throttle shaft part No 691321
Dust seal choke shaft part No 693867
Float hinge pin part No 691242
Air cleaner gasket part No 272653
Welch plug (sold in kit only)
http://www.amazon.co.uk/Briggs-Stratton-Genuine-498260-Carburetor/dp/B0038U3HP4
http://www.ebay.co.uk/itm/OEM-Briggs-Stratton-498260-Carburetor-Overhaul-Kit-/320658799544
