Cincyredsfan513
- Mar 29, 2021
- 1
- 1
I have a Briggs 128602 0151 on a Sarlo mower. It has a carb with primer but no choke. It will start after a couple of primes but will stop unless the primer is pushed to feed more gas. This stops once the engine warms up. I have already taken the carb apart and cleaned it in an ultrasonic cleaner, the needle and seat were also replaced. It is easy to start when cold, just needs help to get it warm, then it’s fine. Any idea of what is going on? Thanks.
