Engine engine clutch
all.i.do.is.mow
Good morning, went out to start my normal day and mounted my exmark 60 mower, got it started and engaged pto, the engine clutch thingy, mounted on the rear mule belt pulley started to make a weird noise, just replaced belt with a new one last week. nay help?
Exmark1
Please contact Exmark Customer Service at 800-667-5296 with your model number and serial number. The team is staffed with trained technicians from the factory who can help you troubleshoot your issue. Thanks.
mechanic mark
Sounds like you have an idler pulley bearing going out or spindle bearings in need of grease.
