Emulsion tube required (even a second hand one)
Quovadisuk
Hi all I am trying to find an emulsion tube for a carb I have it has stamped on the carb 1606 jfb The tube is off white in colour and has only one jet hole on the bottom part of the tube .It has the normal two rubber seals ( one each end ) If anyone has one of this I really would appreciate it even if its old or used kind regards Paul
Yes that sounds like a Tech carb to me........ They have the different colors for the different HP's engines ........
What HP engine you have ??
Also what is the model number ??
