Electrical question
n2qlt
Hello. I have a 26 year old XW2400. About a month ago, the electric suddenly cut out in the middle of a cutting. Unfortunately, I can't find anyone who wants to work on it. It just stopped running. Nothing happens when I turn the ignition key. The battery is only one year old. I checked the fuse, it is good. There is a wiring harness and there is a green wire coming out of it with nothing attached but a crimp connector. There is also a round piezo thingy on the frame, and the negative lead was disconnected. I tried to put two and two together and I stripped and connected together the two disconnected leads. No change. Any advice on this would be most appreciated!View attachment 61542View attachment 61543
Please disregard this post. I ran into a problem and ended up with basically the same post twice. Can't figure out how to delete this one. And the mower problem is already solved!
