Electrical Issue
j-ddowd@juno.com
Cub Cadet 1641 - Model # 144-653-100 - Serial # 859433 - Date Code C164G2
At first I couldn't get the electric PTO clutch to stay engaged unless I held the switch in the up position. Adjusted clutch clearance and installed a new switch. Same problem. While trying to diagnose problem the engine started skipping. It was running on just one cylinder (Briggs Twin). After a running few minutes I lost spark on the other cylinder and it will not start now. No spark. Anyone have an idea? Are the two problems related.
