- Sep 7, 2024
- 3,456
This comes back to what I mentioned earlier about keeping treated gas in the fuel tank for starting and warmup, then shut the gasoline fuel valve off. As the engine dies down, open the propane tank valve and run it on propane. It is a pretty smooth transition.
For mine, I did not want to go through the expense or the hassle of adding electric start on this small 5500/8250 Watt generator of mine, especially after the cost of just fitting it with all of the propane kit
