Electric clutch removal on M665
maxpeterson2002
The PTO clutch on my M665 has died. I get 12V at the connector when the machine is running and I pull the activation switch to the ON position but the clutch doesn't engage. I replaced it 5(?) years ago but don't remember how to get the clutch off.
I've removed the center bolt but the unit doesn't pull off. There looks to be a section of the shaft (into which the center bolt threaded) which has an outside diameter larger than the bearing of the clutch, it has two flats on it to prevent the shaft from turning while you remove the center bolt.
What am I not seeing or understanding about how to get the clutch off??
Tapped it gently with a hammer multiple time and then yanked it as hard as I could and it came off. Bullet dodged.
