I know from experience the thing that makes the most difference is how thick the blade itself is, because they do make them in varying degrees of thickness... Looking at them sideways the thicker blades are usually 1/8" thick, not sure on the thinner ones but I can tell you the difference is visible. I have found generally the thinner blades to be cheaper and the thicker ones last longer, but in all fairness it's six of one or a half dozen of the other, I do mildly prefer the thicker ones as I have to replace them less but it's a close call in terms of price.
'Rotating' the blade after use so as to 'round' the edge that's still sharp helps save money.
