Echo SRM-265T weed eater , it will start only in high rpm all the time, it won稚 idle, if I try to idle it will shutoff, it does runs good on full throttle but I do need some time less power and I can稚 used it like this..Any idea, there are no adjusting screws, only idle screw is present and it does not help at all
I also have a echo edger srm-200, prime bulb does not get fuel, I try to prime but no fuel is getting inside the prime bulb, fuel filter and lines and bulb are all ok, I did a carb cleaning job myself, is there anything hidden inside the carburetor that I have to remove to get it clean?Carb part number: Zama RB-K75
I will really appreciate any help..Thank You
