glimfeather
- Mar 11, 2017
- 1
I've got an Echo TC210 Tiller. Purchased it last year and used it to till a small garden and it worked great. Left it outside up against the house in a somewhat sheltered area but it has a little exposure. This season, I'm having a hard time keeping it running. I did leave some fuel in it over the season - stupid, I know. Don't know why I did that as I always run my gas out on my other equipment.... I have been able to get it started and have begun to start tilling, however after about 2-3 minutes the tiller does not turn and then the engine will bog down and die. Can restart after that but same problem - tines won't rotate and then the engine bogs down. The motor also will not start without fulling depressing the throttle. Do I need to make some carb adjustments for the starting problem? But what about it stopping after a few minutes?
Thanks!
Thanks!
