EBZ7001 Blower won't stay running
parkkilamichael
I have an EBZ 7001 blower and it has been giving me some problems. When the engine is first started cold, it will run smoothly for about ten minutes, then start to bog in and out like the engine is sick and holding back. It will bog in and out for about another ten minutes then it will finally stall. If you try to fire it back up, it will stay running but bog in and out and once again and stall. However, if you give the engine a rest and come back to it fresh, it will run fine for ten minutes, but after ten minutes it again bogs in and out and eventually stalls. If you can give me any tips on how to correct this problem I would highly appreciate it since the landscape season is coming soon.
I have used new plugs, spark plug has a good spark, intake and outtake is clear and good, compression is good, and I've even installed a new carbureater. There's no leaks but maybe a gasket problem? Get back to me. Thank you.
Kodie's Lawn Service
I am thinking a stronger oil mix like a 45 or 40 instead of 50 and Carb Adjustment maybe i am not so sure and have you changed the air filter and and fuel line and filter ????:thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup: Not sure though
