Easy Fix??
lastdaze04
I have a Snapper LT 14.5 and the left rear axle came out of the differential. How hard is it to fix??
Sheets
As a previous Snapper owner, I would advise you that it would be a lot less cheaper & time consuming to buy another used one (hopefully without the same issue). :eek:
twall
I have a Snapper LT 14.5 and the left rear axle came out of the differential. How hard is it to fix?? .
......That would depend how good you are with a wrench. :thumbsup:
It is a DIFFERENTIAL, after all. If you're comfortable with your skilz, it's not bad - especially on a Snapper.......
