I have a JD Model E130 riding mower 2018 year which has a loose mower belt and the belt sometimes comes off. On other JD models there is an adjustment bracket for the belt tension which comes loose with 2 bolts and it can be moved forward and backward to adjust the belt tension. For some reason the JD E130 has a bracket that is welded to the mower deck and there is no apparent way to adjust the tension of the belt.
Can anyone give me advice on how to adjust the belt tension(and why JD would weld this bracket on this model and not on other models)?
Thanks for any help.
