If you clean it surgically clean, Loctite should work (I doubt it will work if there is 2 cycle oil residue left in the carb).
There is usually a lot of debris in the bowl where the screen is located,,,make sure to clean that out.
Lawn-Boy kind of skimped on this model as the only fuel filter is inside the carb.
Regards
Jeff
