Drive stopped mid mow
Jaqsdad
New here, I have a Husky YTH20K46, 420 hrs in the middle of mowing it just stopped moving. Cranks fine just not moving, help plz. If it need fluid in tranny how can I tell.
You need to get down and look up inside the frame rails to see if the drive belt came off or broke.
Jaqsdad
I saw the drive belt and looks like it's still tight and in place./// After closer inspection, I took the deck off and could see the belt had jumped above the rear pulley so it looked in place. Thank you for this forum. I will need it again
