Drive pulley
jb1071
I have a Cub Cadet XT2 LX54. Trying to replace drive belt... strung through transmission and engine pulleys. It showed to remove tensioner pulleys. How do I get back on? Has plate below pulleys so can't see ....
Catherine
LawnWorld Support
Staff member
Welcome to the forum! I'm going to move this thread over to our Cub Cadet section. You should find some advice over there.
You not going like this but it looks like the plate #10 needs to removed or partially removed and the belt install around the pulleys and the plate re-installed as idler bracket is install on it.
If you take either one the pulley nuts loose they need re-tighten to 252-275 in-lbs.
