I bought this machine about 6 years ago but it hasn't been used for about 4 years since I moved and didn't need to use it anymore. Well now I bought a new house and I can't seem to get it to fire but to be honest with you even when it was new it was kinda hard to start when cold. Anyway, I am not a total novice when it comes to small engines, I can normally figure these things out relatively easily but this one I am stumped. This is what I have so far: it has great spark and the compression seems more than adequate to run. I just did a carb rebuild so I know its not the diaphragms in the carb. I removed the air cover and sprayed gas directly into the engine and you would think I would get a little bit of fire but I yank and yank forever and I could not get it to kick over one sputter. What could be the problem? Could it be that I have great spark out of the engine but when it is in the cylinder it is not producing enough? I can't think of anything other than that...let me know if anyone has any other ideas.
Thanks!
Thanks!
