SeniorCitizen
- Aug 28, 2010
- 132
- 2,180
If your JD has blade nuts with dimples sell them as scrap iron and replace them with nuts without dimples. The dimple will clearly be visible on a hex flat. Below is a copied post that tells the end result sooner or later. This is a grave error on John Deere's part and there will never be a recall but you will eventually get to purchase a new blade spindle assembly (s) because of it.
Copied:
This past weekend I went to remove the mowing deck blades for the first time. I found one spindle that may have an issue. The nut was difficult to remove even when not compressed against the blade. Once I removed the blade I tried hand tightening the nut on the spindle and it wouldn't budge. It feels like it is stripped but I can't visibly see damage.
Copied:
