I recently acquired a 2002 Sabre by John Deere. It's the Model number 2554HV. It has a Kohler Command 25hp engine in it, Model Number CV25S (no longer made). The battery won't hold a charge for longer than a few days when I run it.... and that's with the new regulator/rectifier I just installed in it. Before that, it wouldn't last a day because the electric PTO was draining it. My dad was being nice and bought me a battery that was on sale for $18.99, but it's only rated for up to a 12 hp engine. The specs call for a battery rated in the BCI Group Size - U1. I found one at Tractor Supply for $37.99 + core exchange. My dad just bought a new Cub Cadet with the 25 hp Kohler and his battery is rated at 300 cold cranking amps, another reason why I think I just need a bigger battery.
I used an AMP Meter on the battery with engine off, it shows 12.4 amps... when running wide open, it shows 13.5 and when I turn the PTO on, it goes up to a little over 14 amps. Can anyone help me out with this, or at least confirm my suspicions about needing a bigger battery?
Thanks in advance,
Doug
Thanks in advance,
Doug
