LarryJohnson
- May 30, 2017
- 34
- 131
I couldn't see paying $35 for a plastic mulch cover plate. Couldn't find a used one. Thought about making one from wood, but don't have a steam box to bend the wood. Sheet metal crossed my mind, but I've never had the skills to cut it properly and I only have hand shears. Had a bright idea of using a old tire. Went to a local store and set out cutting it up. It was a royal pain cutting the tire. I used about every tool I own. A jig saw with metal blade worked best. Used it once, but the fit wasn't the best. Grass found an exit out the front of the plate. Made a second attempt to tighten it up, but no luck. I ended up cutting a plastic bucket. Ruined the first one. Used a pair of snips and a torch to get the second one to fit well. Added a couple of rivets for strength. Used it today. Works better than the tire at keeping grass under the mower, but still needs some sealing. Going to add foam insulation strips to it for next time.
