Dixon ZTR 5423
Naylor
I have a Dixon ZTR 5423 that keeps throwing the drive belt. The drive belt is new and the pulley is new but every time I put the belt back, crank the mower - it throws the drive belt off again. A friend did tighten the nut on the brake before I replaced the belt. Any ideas what is going on?
Catherine
LawnWorld Support
:welcome:
:confused3: I'm going to move your thread over to our Dixon section to see if we can find you an answer.
BlazNT
With the belt off check for hydro pulley movement. You may have one locked up.
