Dixon engine exchange
260321jd
I just installed a new B&S 21R707, 10.5hp engine in a 2001 model 3303 Dixon ZTR. Does anyone know how to hook up the electrical connections?
I connected the single black wire on the new engine to a similar black wire which was in the old setup. On the old set up there is something on the wire like maybe a resistor. I can start the mower and use its features but the ignition key does not shut down the engine after it is running. The new B&S engine has a red and white wire with a larger female plastic connector attached. The mating connector has approx. 8" to 10" of like wires with approx. 1/2" od the insulation removed.
Any ideas????.
Thanks,
Jim
BlazNT
I need the model numbers of both.
260321jd
Thanks for the quick reply!
The mower is a Dixon 10.5 HP with a B&S 28B 700 engine, 30" ZTR 3303 built in 2001 SN = DM-30-65601.
The new B&S engine: MODEL = 21R707
TYPE = 0011
TRIM = G1
CODE = 140729ZA
