Dixon 60” ZTR wiring diagram
Gravelier
I have a Dixon ZTR 60” Kodiak mower with a 25 hp Kohler command pro engine. I bought it a couple months ago and was told it is a 2009 model. I can’t find any tag showing model or serial number. I’m looking for a wiring diagram. Some diagrams that I have found show a circuit breaker. Mine does not have a circuit breaker, it has 3 fuses. Two 7.5 amp and one 20 amp. One of the 7.5 amp fuses was blown. I replaced it. It started fine, but as soon as I moved either motion control or release the brake, it kills the engine. If the motion controls are in the outward position and the brake on, the deck can be energized and run as long as you want. But move the motion control arm or release the brake and it kills the engine. I removed the fuse and mowed my lawn just fine.
However, it loses power uphill and in heavy grass. I’m going to pull the drive belts and check for anything binding or abnormally tight.
If anyone can send me a link to a wiring diagram. It would be greatly appreciated.
